gemstone@gemstone:~$ dmesg | grep -Ei "usb|xhci|hid|hub"
[ 1.346624] usbcore: registered new interface driver usbfs
[ 1.346663] usbcore: registered new interface driver hub
[ 1.346731] usbcore: registered new device driver usb
[ 4.198786] xhci-hcd xhci-hcd.5.auto: xHCI Host Controller
[ 4.198824] xhci-hcd xhci-hcd.5.auto: new USB bus registered, assigned bus number 1
[ 4.199329] xhci-hcd xhci-hcd.5.auto: hcc params 0x200073c9 hci version 0x100 quirks 0x0000002000008010
[ 4.199588] xhci-hcd xhci-hcd.5.auto: irq 583, io mem 0x31210000
[ 4.200052] xhci-hcd xhci-hcd.5.auto: xHCI Host Controller
[ 4.200070] xhci-hcd xhci-hcd.5.auto: new USB bus registered, assigned bus number 2
[ 4.200091] xhci-hcd xhci-hcd.5.auto: Host supports USB 3.0 SuperSpeed
[ 4.200414] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.12
[ 4.200423] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.200430] usb usb1: Product: xHCI Host Controller
[ 4.200435] usb usb1: Manufacturer: Linux 6.12.24-ti xhci-hcd
[ 4.200440] usb usb1: SerialNumber: xhci-hcd.5.auto
[ 4.202052] hub 1-0:1.0: USB hub found
[ 4.202097] hub 1-0:1.0: 1 port detected
[ 4.203850] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 4.204002] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.12
[ 4.204010] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.204017] usb usb2: Product: xHCI Host Controller
[ 4.204022] usb usb2: Manufacturer: Linux 6.12.24-ti xhci-hcd
[ 4.204027] usb usb2: SerialNumber: xhci-hcd.5.auto
[ 4.204898] hub 2-0:1.0: USB hub found
[ 4.204942] hub 2-0:1.0: 1 port detected
[ 5.104211] usb 1-1: new high-speed USB device number 2 using xhci-hcd
[ 6.052245] usb usb1-port1: Cannot enable. Maybe the USB cable is bad?
[ 6.176199] usb 2-1: new SuperSpeed USB device number 2 using xhci-hcd
[ 6.192547] usb 2-1: New USB device found, idVendor=0451, idProduct=8140, bcdDevice= 1.00
[ 6.192562] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 6.193873] hub 2-1:1.0: USB hub found
[ 6.193968] hub 2-1:1.0: 4 ports detected
[ 7.144234] usb usb1-port1: Cannot enable. Maybe the USB cable is bad?
[ 7.144504] usb usb1-port1: attempt power cycle
[ 7.808247] usb 1-1: new high-speed USB device number 4 using xhci-hcd
[ 7.825348] usb 1-1: New USB device found, idVendor=0451, idProduct=8142, bcdDevice= 1.00
[ 7.825374] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=1
[ 7.825380] usb 1-1: SerialNumber: 26020879A780
[ 7.827114] hub 1-1:1.0: USB hub found
[ 7.827252] hub 1-1:1.0: 4 ports detected
[ 8.112221] usb 1-1.1: new full-speed USB device number 5 using xhci-hcd
[ 8.203228] usb 1-1.1: New USB device found, idVendor=046d, idProduct=c534, bcdDevice=29.00
[ 8.203251] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 8.203258] usb 1-1.1: Product: USB Receiver
[ 8.203264] usb 1-1.1: Manufacturer: Logitech
[ 8.986339] hid: raw HID events driver (C) Jiri Kosina
[ 9.003162] usbcore: registered new interface driver usbhid
[ 9.003179] usbhid: USB HID core driver
[ 10.384456] input: Logitech USB Receiver as /devices/platform/bus@f0000/f920000.usb/31200000.usb/xhci-hcd.5.auto/usb1/1-1/1-1.1/1-1.1:1.0/0003:046D:C534.0001/input/input1
[ 10.609670] hid-generic 0003:046D:C534.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-xhci-hcd.5.auto-1.1/input0
[ 10.612553] input: Logitech USB Receiver Mouse as /devices/platform/bus@f0000/f920000.usb/31200000.usb/xhci-hcd.5.auto/usb1/1-1/1-1.1/1-1.1:1.1/0003:046D:C534.0002/input/input2
[ 10.615117] input: Logitech USB Receiver Consumer Control as /devices/platform/bus@f0000/f920000.usb/31200000.usb/xhci-hcd.5.auto/usb1/1-1/1-1.1/1-1.1:1.1/0003:046D:C534.0002/input/input3
[ 10.668961] input: Logitech USB Receiver System Control as /devices/platform/bus@f0000/f920000.usb/31200000.usb/xhci-hcd.5.auto/usb1/1-1/1-1.1/1-1.1:1.1/0003:046D:C534.0002/input/input4
[ 10.670104] hid-generic 0003:046D:C534.0002: input,hiddev0,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-xhci-hcd.5.auto-1.1/input1
gemstone@gemstone:~$ lsusb
Bus 002 Device 002: ID 0451:8140 Texas Instruments, Inc. TUSB8041 4-Port Hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 005: ID 046d:c534 Logitech, Inc. Unifying Receiver
Bus 001 Device 004: ID 0451:8142 Texas Instruments, Inc. TUSB8041 4-Port Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
gemstone@gemstone:~$ lsusb -t
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 5000M
|__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/4p, 5000M
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 480M
|__ Port 1: Dev 4, If 0, Class=Hub, Driver=hub/4p, 480M
|__ Port 1: Dev 5, If 0, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 1: Dev 5, If 1, Class=Human Interface Device, Driver=usbhid, 12M
Denedim, yukarıdaki klavye ve fareyi gördüğü hali.
[ 1.340548] usbcore: registered new interface driver usbfs
[ 1.340589] usbcore: registered new interface driver hub
[ 1.340674] usbcore: registered new device driver usb
[ 4.372114] xhci-hcd xhci-hcd.5.auto: xHCI Host Controller
[ 4.372153] xhci-hcd xhci-hcd.5.auto: new USB bus registered, assigned bus number 1
[ 4.372636] xhci-hcd xhci-hcd.5.auto: hcc params 0x200073c9 hci version 0x100 quirks 0x0000002000008010
[ 4.372954] xhci-hcd xhci-hcd.5.auto: irq 583, io mem 0x31210000
[ 4.373450] xhci-hcd xhci-hcd.5.auto: xHCI Host Controller
[ 4.373473] xhci-hcd xhci-hcd.5.auto: new USB bus registered, assigned bus number 2
[ 4.373496] xhci-hcd xhci-hcd.5.auto: Host supports USB 3.0 SuperSpeed
[ 4.373743] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.12
[ 4.373753] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.373760] usb usb1: Product: xHCI Host Controller
[ 4.373765] usb usb1: Manufacturer: Linux 6.12.24-ti xhci-hcd
[ 4.373770] usb usb1: SerialNumber: xhci-hcd.5.auto
[ 4.374690] hub 1-0:1.0: USB hub found
[ 4.374729] hub 1-0:1.0: 1 port detected
[ 4.376408] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 4.376557] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.12
[ 4.376566] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.376573] usb usb2: Product: xHCI Host Controller
[ 4.376578] usb usb2: Manufacturer: Linux 6.12.24-ti xhci-hcd
[ 4.376583] usb usb2: SerialNumber: xhci-hcd.5.auto
[ 4.377390] hub 2-0:1.0: USB hub found
[ 4.377442] hub 2-0:1.0: 1 port detected
[ 5.449491] usb usb1-port1: Cannot enable. Maybe the USB cable is bad?
[ 5.569472] usb 2-1: new SuperSpeed USB device number 2 using xhci-hcd
[ 5.586294] usb 2-1: New USB device found, idVendor=0451, idProduct=8140, bcdDevice= 1.00
[ 5.586316] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 5.587805] hub 2-1:1.0: USB hub found
[ 5.587947] hub 2-1:1.0: 4 ports detected
[ 6.537417] usb usb1-port1: Cannot enable. Maybe the USB cable is bad?
[ 6.537693] usb usb1-port1: attempt power cycle
[ 7.553467] usb usb1-port1: Cannot enable. Maybe the USB cable is bad?
[ 8.501481] usb usb1-port1: Cannot enable. Maybe the USB cable is bad?
[ 8.501836] usb usb1-port1: unable to enumerate USB device
bu da görmediği hali. umarım yardımcı olabilmişimdir.
